Datasheet Texas Instruments UCC1806J883B — Даташит
| Серия | UCC1806 |
| Модель | UCC1806J883B |
Маломощный ШИМ-контроллер с двумя выходами в токовом режиме 16-CDIP от -55 до 125
Low Power Dual Output Current Mode PWM Controller datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 24 авг 2006
Купить UCC1806J883B на РадиоЛоцман.Цены — от 2 157 до 3 401 ₽7 предложений от 7 поставщиков Активная деталь, Current Mode PWM Controller 500mA 52kHz 16Pin CDIP Tube | |||
| UCC1806J883B Texas Instruments | 2 157 ₽ | ||
| UCC1806J883B Texas Instruments | 3 401 ₽ | ||
| UCC1806J883B Texas Instruments | по запросу | ||
| UCC1806J/883B | по запросу | ||
| Pin | 16 | 16 | 16 |
| Package Type | J | J | J |
| Industry STD Term | CDIP | CDIP | CDIP |
| JEDEC Code | R-GDIP-T | R-GDIP-T | R-GDIP-T |
| Package QTY | 1 | 1 | 1 |
| Carrier | TUBE | TUBE | TUBE |
| Маркировка | UCC1806J/883B | 5962-9457501ME | A |
| Width (мм) | 6.92 | 6.92 | 6.92 |
| Length (мм) | 19.56 | 19.56 | 19.56 |
| Thickness (мм) | 4.57 | 4.57 | 4.57 |
| Pitch (мм) | 2.54 | 2.54 | 2.54 |
| Max Height (мм) | 5.08 | 5.08 | 5.08 |
| Mechanical Data | Скачать | Скачать | Скачать |
| Control Method | Current |
| Duty Cycle(Max) | 50 % |
| Frequency(Max) | 1000 kHz |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Special Features | Error Amplifier,Soft Start,Synchronization Pin |
| Topology | Boost,Flyback,Forward |
| UVLO Thresholds On/Off | 7.5/6.75 В |
| Vin(Max) | 15 В |
| Vin(Min) | 6.75 В |
| RoHS | See ti.com |
- DN-51 Programming the UCC3806 FeaturesPDF, 154 Кб, Файл опубликован: 5 сен 1999
The UCC3806 is a pin-for-pin-compatible BiCMOS replacement for the UC3846 and UC3856. However, this design note explains how some functions in the UCC3806 are programmed differently. In particular, the CUR LIM ADJ pin programs the maximum peak current for the current-sense amplifier. This function is completely compatible with that of previous ICs. The second function on this pin is the latch/non- - U-144 UCC3806 BiCMOS Current Mode Control ICPDF, 285 Кб, Файл опубликован: 5 сен 1999
The UCC3806 BiCMOS current-mode controller has the advantages of reductions in current consumption, in power loss, and in propagation delays within the IC. The UCC3806 is pin-for-pin compatible with the popular UC3846 and UC3856 controllers. With minimal part changes, this device may be suitable for retrofit into many existing designs where higher power consumption and propagation delays posed pro - DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICsPDF, 27 Кб, Файл опубликован: 5 сен 1999
The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806 - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UCC1806 (6)
- 5962-9457501MEA 5962-9457501Q2A UCC1806J UCC1806J883B UCC1806L UCC1806L883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
