Datasheet Texas Instruments LM3S2B93-IBA80-C5 — Даташит
СерияLM3S2B93
МодельLM3S2B93-IBA80-C5
Stellaris LM3S2B93 Microcontroller Data Sheet datasheet
PDF, 6.8 Мб, Версия: O, Файл опубликован: 3 июл 2014
Pin103
Package TypeZCW
Width (мм)7.5
Length (мм)7.5
Thickness (мм).96
RoHSНе совместим
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S2B93IBA80C5, LM3S2B93 IBA80 C5
На английском языке: Datasheet Texas Instruments LM3S2B93-IBA80-C5
