Оптопары и оптореле Megawin
Datasheet Texas Instruments 5962-8951105EA — Даташит
СерияUC1525B
Модель5962-8951105EA
Регулирующие широтно-импульсные модуляторы 16-CDIP от -55 до 125
Regulating Pulse Width Modulators datasheet
PDF, 2.4 Мб, Файл опубликован: 5 сен 1999
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodVoltage
Duty Cycle(Max)50 %
Основные особенностиError Amplifier,Soft Start,Synchronization Pin,Multi-topology
Frequency(Max)500 kHz
Frequency(Min)0.1 kHz
Package GroupCDIP
RatingMilitary
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off7/6.8 В
Vin(Max)35 В
Vin(Min)8 В
RoHSSee ti.com
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • DN-36 UC1525B/UC1527B Devices - Comparison Summary to UC1525A/27A Devices
    PDF, 19 Кб, Файл опубликован: 5 сен 1999
    The UC1525B and UC1527B are enhanced versions of the previous generation of UC1525A and UC1527A devices. They are pin-for-pin compatible and direct replacements for the A versions in almost all applications. The table in this design note compares the two sets of devices. Significant improvements have been made in the 5.1 V reference voltage and the output drivers as itemized in the table.
Серия: UC1525B (3)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59628951105EA, 5962 8951105EA
На английском языке: Datasheet Texas Instruments 5962-8951105EA
