Datasheet Texas Instruments TPS56100PWP — Даташит
СерияTPS56100
МодельTPS56100PWP
5-битный программируемый синхронный понижающий контроллер 28-HTSSOP от 0 до 70
High-Efficiency DSP Power Supply Controller For 5-V Input Systems datasheet
PDF, 525 Кб, Версия: A, Файл опубликован: 2 авг 1999
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS56100
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTPS53355DQPR
Replacement CodeF
  • Using the TPS56100 to Power DSPs (Rev. B)
    PDF, 58 Кб, Версия: B, Файл опубликован: 7 мар 2000
    The synchronous buck converter controllers (TPS56100, TPS56300, TPS56xx, and TPS5602) made by Texas Instruments are specifically designed to provide excellent transient response and high efficienty to the microprocessor power applications such as the TMS320C6000 and TMS320C5000 DSP families from TI, as well as similar high-speed digital loads. In addition, hysteresis control method is used such th
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
Серия: TPS56100 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS56100PWP
