Datasheet Texas Instruments ADS8556IPMR — Даташит
СерияADS8556
МодельADS8556IPMR
630kSPS, 6-канальный АЦП с одновременной выборкой 64-LQFP от -40 до 125
ADS855x 16-, 14-, 12-Bit, Six-Channel, Simultaneous Sampling Analog-to-Digital Converters datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 3 фев 2016
Pin6464
Package TypePMPM
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY10001000
CarrierLARGE T&RLARGE T&R
Маркировка8556IADS
Width (мм)1010
Length (мм)1010
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
# Input Channels6
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)3 +/-LSB
Input Range(Max)12 В
Input Range(Min)-12 В
Тип входаSingle-Ended
Integrated FeaturesDaisy-Chainable,Oscillator
InterfaceParallel,SPI
Multi-Channel ConfigurationSimultaneous Sampling
Package GroupLQFP
Package Size: mm2:W x L64LQFP: 144 mm2: 12 x 12(LQFP) PKG
Power Consumption(Typ)335 mW
Reference ModeExt,Int
Разрешение16 Bits
SINAD89.5 дБ
SNR91.5 дБ
Sample Rate (max)630kSPS SPS
Sample Rate(Max)0.63 MSPS
THD(Typ)-94 дБ
  • Evaluation Modules & Boards: ADS8556EVM
    ADS8556 Evaluation Module
  • Driver Circuit Design Considerations for ADS855x
    PDF, 1.3 Мб, Файл опубликован: 27 авг 2012
  • A Numerical Protection Relay Solution
    PDF, 187 Кб, Файл опубликован: 2 сен 2010
    Numerical Protection Relays (NPRs) are critical elements in any power distribution network. Generally, there are several different types of NPRs. Each type, however, shares a similar architecture, thus enabling designers to build an entire system solution that is based on a relatively small number of flexible components. This application note demonstrates how an NPR can be implemented using TI's e
Серия: ADS8556 (2)
На английском языке: Datasheet Texas Instruments ADS8556IPMR
