Datasheet Texas Instruments TPS61093QDSKTQ1 — Даташит
СерияTPS61093-Q1
МодельTPS61093QDSKTQ1
Автомобильный повышающий преобразователь 6 В/17 В, 1,1 А со встроенным силовым диодом 10-SON от -40 до 125 В.
TPS61093-Q1 Low Input Boost Converter With Integrated Power Diode and Input/Output Isolation datasheet
PDF, 1.1 Мб, Файл опубликован: 30 янв 2015
Pin10
Package TypeDSK
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Width (мм)2.5
Length (мм)2.5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Approx. Price (US$)1.69 | 1ku
Duty Cycle(Max)(%)93
Iq(Typ)(mA)0.9
Operating Temperature Range(C)-40 to 125
Package GroupSON
RatingAutomotive
Regulated Outputs(#)1
Special FeaturesEnable
Output Discharge
Switch Current Limit(Typ)(A)1.1
Switching Frequency(Max)(kHz)1400
ТипConverter
Vin(Max)(V)6
Vin(Min)(V)1.6
Vout(Max)(V)17
Vout(Min)(V)1.7
RoHSНе совместим
  • Evaluation Modules & Boards: TPS61093EVM-519
    TPS61093EVM-519 Evaluation Module
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS61093-Q1 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61093QDSKTQ1
