Datasheet Texas Instruments DAC8820IBDBR — Даташит
СерияDAC8820
МодельDAC8820IBDBR
16-битный ЦАП с умножением на параллельный вход 28-SSOP от -40 до 85
16-Bit, Parallel Input Multiplying Digital-to-Analog Converter datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 19 фев 2008
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаDAC8820
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
Code to Code Glitch(Typ)2 nV-sec
DAC ArchitectureMultiplying DAC
DAC Channels1
Gain Error(Max)0.02 %FSR
INL(Max)1 +/-LSB
InterfaceParallel
Offset Error(Max)N/A %
Output Range Max.2 mA/V
Тип выходаUnbuffered Current
Package GroupSSOP
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Power Consumption(Typ)0.025 mW
Reference: TypeExt
Разрешение16 Bits
Sample / Update Rate2 MSPS
Время установления0.5 µs
Special FeaturesN/A
Zero Code Error(Typ)N/A мВ
  • Evaluation Modules & Boards: DAC8820EVM
    DAC8820EVM Evaluation Module
  • Interfacing the DAC8806 and DAC8820 to TMS320 DSPs
    PDF, 61 Кб, Файл опубликован: 20 дек 2006
    This application report presents a method for interfacing the DAC8806 and DAC8820 - single-channel, current-output, 14-/16-bit multiplying digital-to-analog converters - to the TMS320 series of digital signal processors. The software developed for this application report creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8806/20EVM to create a +/-10-V
  • Interfacing the DAC8806 and DAC8820 to MSP430 Microcontrollers
    PDF, 53 Кб, Файл опубликован: 20 дек 2006
    This application report presents a method for interfacing the DAC8806 and DAC8820 single-channel, current-output, 14-/16-bit multiplying digital-to-analog converters — to the MSP430F449 processor using the SoftBaugh HPA449 evaluation system. The associated software creates a 256-point sine table, and then continuously writes values from the sine table to the DAC8806/20EVM, which outputs a 10V sin
На английском языке: Datasheet Texas Instruments DAC8820IBDBR
