Datasheet Texas Instruments UC3825QTR — Даташит
СерияUC3825
МодельUC3825QTR
Высокоскоростной ШИМ-контроллер 20-PLCC от 0 до 70
High Speed PWM Controller datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 24 фев 2004
Pin20
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Package QTY1000
МаркировкаUC3825Q
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.06
Max Height (мм)4.57
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)85 %
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Gate Drive(Typ)1.5 A
Package GroupPDIP,SOIC
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Flyback,Forward,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)8.4 В
  • U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power Supply
    PDF, 298 Кб, Файл опубликован: 5 сен 1999
    The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U
  • Current Doubler Rectifier Offers Ripple Current Cancellation
    PDF, 116 Кб, Файл опубликован: 21 сен 2004
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3825QTR
