Datasheet Texas Instruments UC1823AJ — Даташит
| Серия | UC1823A |
| Модель | UC1823AJ |
Высокоскоростной ШИМ-контроллер 16-CDIP от -55 до 125
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Купить UC1823AJ на РадиоЛоцман.Цены — от 3 101 до 10 921 ₽17 предложений от 17 поставщиков Микросхема Контроллер PWM, Current Mode PWM Controller 2A 1000kHz 16Pin CDIP Tube | |||
| UC1823AJ883B Texas Instruments | 3 101 ₽ | ||
| UC1823AJ/883 Texas Instruments | по запросу | ||
| UC1823AJ Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | UC1823AJ |
| Width (мм) | 6.92 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Control Method | Current |
| Duty Cycle(Max) | 100 % |
| Frequency(Max) | 1000 kHz |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Special Features | Error Amplifier,Leading Edge Blanking,Soft Start,Synchronization Pin,Multi-topology |
| Topology | Boost,Buck,Flyback,Forward |
| UVLO Thresholds On/Off | 9.2/8.4 В |
| Vin(Max) | 22 В |
| Vin(Min) | 8.4 В |
| RoHS | See ti.com |
- U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM ControllersPDF, 204 Кб, Файл опубликован: 5 сен 1999
The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
Серия: UC1823A (6)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
