Линейка продуктов KEEN SIDE
Datasheet Texas Instruments OMAP5912ZDY — Даташит
СерияOMAP5912
МодельOMAP5912ZDY
OMAP5912 Applications Processor datasheet
PDF, 2.5 Мб, Версия: E, Файл опубликован: 19 дек 2005
Pin289289289
Package TypeZDYZDYZDY
Industry STD TermBGABGABGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY848484
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаOMAP5912OMAPZDY
Width (мм)191919
Length (мм)191919
Thickness (мм)1.731.731.73
Pitch (мм)111
Max Height (мм)2.322.322.32
  • JTAG Emulators/ Analyzers: TMDSADP
    Adaptive Clocking JTAG Emulator Adapters
  • DSP Instruction Cache Performance on the OMAP5912
    PDF, 47 Кб, Файл опубликован: 28 фев 2005
  • Enabling high-speed USB OTG functionality on TI DSPs
    PDF, 191 Кб, Файл опубликован: 18 май 2007
  • OMAP591x: Tuning the System Memory Requirements of DSP/BIOS Link
    PDF, 251 Кб, Файл опубликован: 16 мар 2005
    The DSP/BIOSв„ў Link software has been designed to implement inter-processor communication between a host device and a DSP. For the case of OMAP591x devices, the default configuration of the DSP/BIOS Link software requires that 2MB of system memory is reserved for exclusive use by DSP/BIOS Link. The intention was to provide developers using DSP/BIOS Link plenty of memory to begin with and enab
  • Programming the DSP MMU in the OMAP5910 Device
    PDF, 476 Кб, Файл опубликован: 7 окт 2004
    The OMAP5910 device from Texas Instruments (TI) has a new dual-core architecture that is optimized for multimedia applications in a low-power environment. It couples two processorsВ—a TI-enhanced TI925T general-purpose processor and an ultralow-power TMS320C55xв„ў (C55xв„ў) digital signal processor (DSP)В—with a rich set of peripherals and powerful interfaces to achieve optimal per
  • Using the CSL to complement OS dispatcher in handling Cascaded Interrupts
    PDF, 299 Кб, Файл опубликован: 8 ноя 2004
    This application report discusses how CSL's INTC module could be used to share the task of dispatching interrupts with the OS, in scenarios where the OS's interrupt dispatcher does not comprehend cascaded interrupts.The solution involves having the CSL dispatch the cascaded interrupts alone, while completely leaving the job of dispatching primary CPU interrupts to the OS.We also discuss an
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: OMAP5912 (3)
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments OMAP5912ZDY
