Datasheet Texas Instruments TMS320C5517AZCH20 — Даташит
СерияTMS320C5517
МодельTMS320C5517AZCH20
Процессор цифровых сигналов с фиксированной точкой 196-NFBGA от -10 до 70
TMS320C5517 Fixed-Point Digital Signal Processor datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 23 апр 2014
Pin196
Package TypeZCH
Industry STD TermNFBGA
JEDEC CodeS-PBGA-N
Package QTY184
CarrierJEDEC TRAY (10+1)
Маркировка17AZCH20
Width (мм)10
Length (мм)10
Thickness (мм).89
Max Height (мм)1.3
ApplicationsCommunications and Telecom,Industrial,Medical
DRAMSDRAM,mSDRAM
DSP1 C55x
DSP MHz75,200 Max.
HPI1 16-Bit HPI
I2C1
McBSP1
Operating SystemsDSP/BIOS,VLX
Рабочий диапазон температурот -10 до 70,-40 до 85 C
Other Hardware AccelerationFFT Coprocessor
SPI1
UART1 SCI
USB1
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: TMDSEVM5517
    C5517 Evaluation Module (EVM)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
  • Power Estimation and Power Consumption summary for TMS320C5517 Device
    PDF, 285 Кб, Файл опубликован: 6 окт 2015
    This application report assists in estimating the power consumption using the power estimation spreadsheet for the TMS320C5517 devices (DSP).
  • Estimating Power Consumption on the TMS320C5517
    PDF, 28 Кб, Файл опубликован: 2 апр 2014
    This article discusses the power consumption of the Texas Instruments TMS320C5517. Power consumption on these devices is highly application-dependent. The low-core voltage and other power design optimizations allow these devices to operate with industry-leading performance, while maintaining alow power-to-performance ratio.The power data presented in this article are based on measured data w
  • Validating High- and Full-Speed USB on TMS320C5517
    PDF, 9.3 Мб, Файл опубликован: 2 апр 2014
    This application report describes the process to validate electrical requirements of high- and full-speed USB operations on the TMS320C5517 device.
  • Using the TMS320C5517 Bootloader
    PDF, 307 Кб, Файл опубликован: 2 апр 2014
    This application report describes the features of the on-chip ROM for the TMS320C5517 device. Included is a description of the bootloader and how to interface with it for each of the possible boot devices, as well as instructions for generating a boot image to store on an external device.
  • Migrating from TMS320C5515 to 5517
    PDF, 144 Кб, Файл опубликован: 2 апр 2014
    The TMS320C5515 and the TMS320C5505 will henceforth in this document be referred to as C5515/05. The TMS320C5517 will henceforth in this document be referred to as C5517.This document provides the minimum changes required to migrate from the C5515/05 to the C5517. Enhancements or new features of the C5517 that do not affect migrating from the C5515/05 to the C5517 are also briefly mentioned in
  • MEMS Microphone Direct PDM Input via I2S to a C5515 EVM With Software Decimation
    PDF, 686 Кб, Файл опубликован: 22 сен 2016
    This application report helps system designers demonstrate and understand the technique of directly feeding a MEMS mic output PDM stream into the Inter-IC Sound (I2S) lines of a C5515 EVM. This document is intended for audiences familiar with Digital Signal Processing, decimation and filtering techniques.
  • Usage Guidelines for C55x On-Chip Low Dropout Regulators (LDOs)
    PDF, 220 Кб, Файл опубликован: 26 июл 2016
    The C5515/C5535/C5545/C5517 devices include three low dropout regulators ANA_LDO, DSP_LDO and USB_LDO. This application report provides the guidelines for using these on-chip low dropout regulators. This document also covers the USB power-up sequence that must be followed when using the device USB.
  • Instructions to Benchmark C55 DSP Library
    PDF, 3.2 Мб, Файл опубликован: 1 апр 2016
    DSP Library (DSPLIB) is a collection of optimized C55x assembly functions that implement a wide variety of DSP functions. The TMS320C55x DSP Library Programmer’s Reference User's Guide provides cycle estimation for the execution of each function in the library. This work enables the user to measure the performances of a sub-set of the DSPLIB functions executed on real hardware, and with some addit
  • C5000 DSP-Based Low-Power System Design
    PDF, 169 Кб, Файл опубликован: 30 ноя 2015
    Low-power consumption is one of the most important requirements for the embedded system. The C5000в„ў ultra low-power DSP family is ideal for portable devices (audio, voice and vision) and other applications that require analytics with low power.To take advantage of this feature in system design, good practices need to be carried out. This application report focuses on the Texas Instrum
  • Sitara Linux ALSA DSP Microphone Array Voice Recognition
    PDF, 529 Кб, Файл опубликован: 30 июн 2017
    Voice recognition applications requiring a superior user experience typically use a number of digital signal processing algorithms to filter, clean, and enhance microphone sampled audio. Frequently these systems will employ multiple microphones where more sophisticated algorithms can be used. These systems can leverage a Texas Instruments Digital Signal Processor to offload the complex real-time c
Серия: TMS320C5517 (2)
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320C5517AZCH20
