Datasheet Texas Instruments OPA140ATDD1 — Даташит
СерияOPA140A-DIE
МодельOPA140ATDD1
High-Precision, Low-Noise, Rail-to-Rail Output, 11MHz JFET Operational Amplifier datasheet
PDF, 99 Кб, Версия: B, Файл опубликован: 27 мар 2012
Package TypeTD
Package QTY252
RoHSSee ti.com
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA140A-DIE (2)
На английском языке: Datasheet Texas Instruments OPA140ATDD1
