Datasheet Texas Instruments V62/06639-02XE — Даташит
СерияDAC5672-EP
МодельV62/06639-02XE
Усовершенствованный продукт Двойной 14-битный цифро-аналоговый преобразователь 48-TQFP со скоростью 200 МГц, от -55 до 125
DAC5672-EP datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 10 окт 2006
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаDAC5672EP
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
АрхитектураCurrent Source
DAC Channels2
DNL(Max)3 +/-LSB
INL(Max)4 +/-LSB
InterfaceParallel CMOS
Output Range Max.20 мА
Output Range Min.2 мА
Тип выходаCurrent
Package GroupTQFP
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Power Consumption(Typ)330 mW
RatingHiRel Enhanced Product
Reference: TypeInt
Разрешение14 Bits
SFDR84 дБ
SNR77 дБ
Sample / Update Rate275 MSPS
Время установления0.02 µs
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
V62/0663902XE, V62/06639 02XE
На английском языке: Datasheet Texas Instruments V62/06639-02XE
Публикации по теме
