Datasheet Texas Instruments LMP91300NHZJ — Даташит
Серия | LMP91300 |
Модель | LMP91300NHZJ |
Индуктивный датчик приближения AFE 24-WQFN от -40 до 125
LMP91300 Industrial Inductive Proximity Sensor AFE datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 27 мар 2014
![]() 10 предложений от 10 поставщиков IC AFE 1 CHAN 16BIT 24WQFN. 1 Channel AFE 16 Bit 24-WQFN (4x5). Data Acquisition - Analog Front End (AFE) | |||
LMP91300NHZJ Texas Instruments | 297 ₽ | ||
LMP91300NHZJ Texas Instruments | по запросу | ||
Pin | 24 |
Package Type | NHZ |
Industry STD Term | WQFN |
JEDEC Code | R-PQSO-N |
Package QTY | 4500 |
Carrier | LARGE T&R |
Маркировка | L91300 |
Width (мм) | 4 |
Length (мм) | 5 |
Thickness (мм) | .8 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Supply (V) | 40 Min |
Interface | SWIF |
Package Group | WQFN |
Package Size: mm2:W x L | 24WQFN: 20 mm2: 4 x 5(WQFN) PKG |
Rating | Catalog |
Sensor Frequency | 5k to 5M Hz |
- Measuring Rp of an L-C Sensor for Inductive SensingPDF, 205 Кб, Файл опубликован: 1 окт 2015
When designing an application using TI’s LDC series of inductive sensors, it is necessary to know the L-C sensor’s equivalent parallel resistance RP at the sensor’s resonant frequency. The RP value changes as the target is moved; the minimum RP occurs when the metal target is closest to the sensor. The maximum RP occurs when the target is at the farthest distance. Accordingly, both values should b
Серия: LMP91300 (5)
- LMP91300NHZJ LMP91300NHZR LMP91300NHZT LMP91300YZRR LMP91300YZRT
- Semiconductors > Sensing Products > Inductive Sensing > Inductive Switches
