Datasheet Texas Instruments LF347N/NOPB — Даташит
СерияLF347-N
МодельLF347N/NOPB
Широкополосные операционные усилители с четырьмя входами JFET 14-PDIP от 0 до 70
LF147/LF347 Wide Bandwidth Quad JFET Input Operational Amplifiers datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 мар 2013
37 предложений от 19 поставщиков
LF347N/NOPB
142 ₽
LF347N/NOPB
193 ₽
LF347N/NOPB
от 323 ₽
LF347N/NOPB
466 ₽
Pin14
Package TypeNFF
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаLF347N
Width (мм)6.35
Length (мм)19.177
Thickness (мм)3.429
Pitch (мм)2.54
Max Height (мм)5.33
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)70 дБ
CMRR(Typ)100 дБ
GBW(Typ)4 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)2.75 мА
Iq per channel(Typ)1.8 мА
Количество каналов4
Offset Drift(Typ)10 uV/C
Output Current(Typ)31 мА
Package GroupPDIP
Rail-to-RailIn to V+
Slew Rate(Typ)13 V/us
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)20 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • AN-447 Protection Schemes for BI-FET Amplifiers and Switches
    PDF, 80 Кб, Файл опубликован: 2 май 2004
    Application Note 447 Protection Schemes for BI-FET Amplifiers and Switches
  • AN-301 Signal Conditioning for Sophisticated Transducers (Rev. B)
    PDF, 1.2 Мб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses signal conditioning and applications information for a diverse group ofsophisticated and unusual transducers.
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • Get More Power Out of Dual or Quad Op-Amps
    PDF, 91 Кб, Файл опубликован: 2 окт 2002
На английском языке: Datasheet Texas Instruments LF347N/NOPB
