Datasheet Texas Instruments THS4304DR — Даташит
Серия | THS4304 |
Модель | THS4304DR |
Широкополосный операционный усилитель 8-SOIC от -40 до 85
THS4304: Wideband Operational Amplifier datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 30 июл 2004
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
2nd Harmonic(dBc) | 84 |
3rd Harmonic(dBc) | 100 |
@ MHz | 10 |
Acl, min spec gain(V/V) | 1 |
Additional Features | N/A |
Approx. Price (US$) | 2.41 | 1ku |
Архитектура | Bipolar Voltage FB |
BW @ Acl(MHz) | 3000 |
CMRR(Min)(dB) | 80 |
CMRR(Typ)(dB) | 95 |
GBW(Typ)(MHz) | 3000 |
Input Bias Current(Max)(pA) | 12000000 |
Iq per channel(Max)(mA) | 18.9 |
Iq per channel(Typ)(mA) | 18 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 5 |
Operating Temperature Range(C) | -40 to 85 |
Output Current(Typ)(mA) | 100 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
Rail-to-Rail | In Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 790 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 5 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.7 |
Vn at Flatband(Typ)(nV/rtHz) | 2.4 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 4 |
RoHS | Не совместим |
- Evaluation Modules & Boards: THS4304DGKEVM
THS4304 Evaluation Module for DGK Package
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: THS4304DBVEVM
THS4304 Evaluation Module for DBV Package
- RF and IF amplifiers with op ampsPDF, 177 Кб, Файл опубликован: 28 фев 2005
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS4304 (9)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
