Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TAS5760MDDCA — Даташит
СерияTAS5760MD
МодельTAS5760MDDCA
Входной усилитель I2S с замкнутым контуром, ограничителем мощности и встроенными наушниками, PVDDмакс.
TAS5760MD General-Purpose I2S Input Class-D Amplifier With DirectPathв„ў Headphone and Line Driver datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 9 май 2017
26,4 В, 48-HTSSOP от -25 до 85
Pin48
Package TypeDCA
Industry STD TermHTSSOP
Package QTY40
МаркировкаTAS5760MD
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)4.5 Max
Audio Input TypeDigital
Closed/Open LoopClosed
Control InterfaceHardware,Software
Рабочий диапазон температурот -25 до 85 C
Package GroupHTSSOP
Package Size: mm2:W x L48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP) PKG
Power Stage Supply(Max)26.4 В
Power Stage Supply(Min)4.5 В
Power to Bridge Tied Load(Max)21.9 W
Power to Parallel Bridge Tied Load(Max)43.2 W
Sampling Rate(Max)96 kHz
Sampling Rate(Min)32 kHz
Speaker Channels2 Max
Supported Bridge Tied Load(Min)4 Ohms
  • Evaluation Modules & Boards: TAS5760XXEVM
    TAS5760M/MD/L/LD Evaluation Module
  • Evaluation Modules & Boards: PUREPATH-CMBEVM
    PurePath Console Mother Board for Audio system design and development
  • TAS57xx Dynamic Range Control
    PDF, 324 Кб, Файл опубликован: 18 июн 2010
    This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5760MD (2)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Digital I2S Input Class-D
На английском языке: Datasheet Texas Instruments TAS5760MDDCA
