Datasheet Texas Instruments 85515022A — Даташит
СерияUC1526A
Модель85515022A
Регулирующие широтно-импульсные модуляторы 20-LCCC от -55 до 125
Regulating Pulse Width Modulator datasheet
PDF, 597 Кб, Файл опубликован: 5 сен 1999
Pin202020
Package TypeFKFKFK
Industry STD TermLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY111
CarrierTUBETUBETUBE
Маркировка85515022A883BUC1526AL/
Width (мм)8.898.898.89
Length (мм)8.898.898.89
Thickness (мм)1.831.831.83
Pitch (мм)1.271.271.27
Max Height (мм)2.032.032.03
Control MethodVoltage
Duty Cycle(Max)50 %
Frequency(Max)600 kHz
Frequency(Min)0.01 kHz
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Synchronization Pin,Multi-topology
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off4.4/4.2 В
Vin(Max)35 В
Vin(Min)7 В
RoHSSee ti.com
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC1526A (6)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments 85515022A
