Datasheet Texas Instruments LM95245CIMM/NOPB — Даташит
СерияLM95245
МодельLM95245CIMM/NOPB
В±2В°C Remote and Local Temperature Sensor with TruTherm Technology and SMBus Interface 8-VSSOP -40 to 125
Precision Diode Digital Temp Sensor w/TruTherm BJT Comp Tech for 45nm Process datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 22 мар 2013
34 предложений от 15 поставщиков
SENSOR DIGITAL -40C-85C 8VSSOP. Temperature Sensor Digital, Local/Remote -40°C ~ 85°C 10 b (Local), 12 b (Remote) 8-VSSOP. Temperature Sensors -...
LM95245CIMM/NOPB
55 ₽
LM95245CIMM/NOPB
110 ₽
Зенер
Россия и страны ТС
LM95245CIMM/NOPB
от 291 ₽
LM95245CIMM/NOPB
Package TypeDGK
Industry STD TermVSSOP
Package QTY1000
CarrierSMALL T&R
МаркировкаT45C
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
InterfaceI2C,SMBus
Local Sensor Accuracy(Max)2 +/- C
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Remote Channel1
Remote Diode Temp Range for Listed Accuracy50 to 105 C
Remote Sensor Accuracy(Max)0.75 +/- C
Remote Sensor CorrectionBeta Compensation,TruTherm
Remote Temp Resolution(Max)13 bits
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering
Supply Current(Typ)350 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
Temp Resolution(Max)11 bits
  • Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM95245CIMM/NOPB
