Оптопары и оптореле Megawin
Datasheet Texas Instruments TL1454ACDB — Даташит
СерияTL1454A
МодельTL1454ACDB
Двухканальная схема управления с широтно-импульсной модуляцией (ШИМ) 16-SSOP от -20 до 85
Dual-Channel Pulse-Width-Modulation (PWM) Control Circuit datasheet
PDF, 882 Кб, Версия: A, Файл опубликован: 25 сен 2002
Pin16
Package TypeDB
Industry STD TermSSOP
Package QTY80
МаркировкаT1454A
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments TL1454ACDB
