Datasheet Texas Instruments TPS25944LRVCR — Даташит
| Серия | TPS25944L |
| Модель | TPS25944LRVCR |
18V, 5A, 42mО© Circuit Breaking Power MUX eFuse w/Integrated Reverse Current Protection, IMON & PG 20-WQFN -40 to 85
TPS25942x/44x 2.7 V-18 V, 5-A eFuse Power MUX With Multiple Protection Modes datasheet
PDF, 3.4 Мб, Версия: C, Файл опубликован: 18 янв 2017
Купить TPS25944LRVCR на РадиоЛоцман.Цены — от 27 до 1 296 ₽36 предложений от 15 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства горячей замены | |||
| TPS25944LRVCR Texas Instruments | 59 ₽ | ||
| TPS25944LRVCR Texas Instruments | от 282 ₽ | ||
| TPS25944LRVCR Texas Instruments | 823 ₽ | ||
| TPS25944LRVCR Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | RVC |
| Industry STD Term | WQFN |
| JEDEC Code | R-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | 25944L |
| Width (мм) | 4 |
| Length (мм) | 3 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Channel(s) Controlled | 1 |
| Current Limit Accuracy | +/-8% |
| Current Limit Function Enabled | Startup Only |
| Current Limit Type | Adjustable |
| Current Limit(Max) | 5.2 A |
| Current Limit(Min) | 0.6 A |
| FET Protection | Thermal |
| Fault Response | Latch Off |
| Imax | 5.2 A |
| Количество каналов | 1 |
| ON_OFF Control Input | ENBLK,ENUV,OV s |
| Overcurrent Response | Circuit Breaking |
| Overvoltage Response | Cutoff |
| Package Group | WQFN |
| Package Size: mm2:W x L | 20WQFN: 12 mm2: 4 x 3(WQFN) PKG |
| Rise Time(Typ) | 120 us |
| Ron(Typ) | 42 mOhm |
| Special Features | Current Sense/Monitor,Fault Reporting,Overvoltage Protection,Power Good,Power MUXing,Reverse Current Protection,Thermal Shutdown,Under Voltage Lock Out |
| UL Recognition | Yes |
| Vabsmax_cont | 20 В |
| Vin(Max) | 18 В |
| Vin(Min) | 2.7 В |
- Evaluation Modules & Boards: TPS25942EVM-635
TPS25942EVM-635 Evaluation Module for TPS25942x
Серия: TPS25944L (2)
- TPS25944LRVCR TPS25944LRVCT
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
