Datasheet Texas Instruments THS4631DGNG4 — Даташит
СерияTHS4631
МодельTHS4631DGNG4
Высокоскоростной операционный усилитель с входом полевого транзистора 8-MSOP-PowerPAD от -40 до 85
High-Voltage High Slew Rate Wideband FET-Input Op Amp datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 17 авг 2011
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаADK
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic76 dBc
3rd Harmonic94 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураFET,Voltage FB
BW @ Acl325 МГц
CMRR(Min)86 дБ
CMRR(Typ)95 дБ
GBW(Typ)325 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)13 мА
Iq per channel(Typ)11.5 мА
Количество каналов1
Offset Drift(Typ)2.5 uV/C
Output Current(Typ)95 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)1000 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7 нВ/rtГц
Vn at Flatband(Typ)7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Evaluation Modules & Boards: THS4631DGNEVM
    THS4631DGNEVM Evaluation Module
  • Evaluation Modules & Boards: THS4631DDAEVM
    THS4631DDAEVM Evaluation Module
  • Transimpedance Considerations for High-Speed Operational Amplifiers
    PDF, 193 Кб, Файл опубликован: 22 ноя 2009
    Designing high-resolution detection circuits using photodiodes presents considerable challenges because bandwidth, gain, and input-referred noise are coupled together. This application note reviews the basic issues of transimpedance design, provides a set of detailed design equations, explains those equations, and develops an approach to easily compare potential solutions.
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
На английском языке: Datasheet Texas Instruments THS4631DGNG4
