Datasheet Texas Instruments LM95213CISD/NOPB — Даташит
СерияLM95213
МодельLM95213CISD/NOPB
В±2В°C Dual Remote and Local Temperature Sensor with SMBus Interface 14-WSON -40 to 140
2-Diode Input & Local Digital Temp Sensor w/ Two-Wire Interface & TCRIT Outputs datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 22 мар 2013
Pin14
Package TypeNHL
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
Маркировка95213CI
Width (мм)4
Length (мм)4
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
InterfaceI2C,SMBus
Local Sensor Accuracy(Max)2 +/- C
Рабочий диапазон температурот -40 до 140 C
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Remote Channel2
Remote Diode Temp Range for Listed Accuracy60 to 100 C
Remote Sensor Accuracy(Max)1.1 +/- C
Remote Sensor CorrectionOffset Correction Register
Remote Temp Resolution(Max)13 bits
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering
Supply Current(Typ)570 uA
Supply Voltage(Max)3.6 В
Supply Voltage(Min)3 В
Temp Resolution(Max)11 bits
  • Evaluation Modules & Boards: LM95213EB
    2-Diode Input and Local Digital Temperature Sensor with Two-Wire Interface and Outputs EVM
Серия: LM95213 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM95213CISD/NOPB
