Datasheet ТI REG103FA-AKTTT — Даташит
| Серия | REG103 |
| Модель | REG103FA-AKTTT |
500 мА, малошумящий регулятор с малым падением напряжения 5-DDPAK/TO-263 от -40 до 85
DMOS 500mA Low-Dropout Regulator datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 22 сен 2005
- LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
- Packaging Limits Range of Linear RegulatorsPDF, 75 Кб, Файл опубликован: 8 май 2010
The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: REG103 (49)
- REG103FA-2.5 REG103FA-2.5/500 REG103FA-2.5/500G3 REG103FA-2.5KTTT REG103FA-2.5KTTTG3 REG103FA-3.3 REG103FA-3.3/500 REG103FA-3.3KTTT REG103FA-3.3KTTTG3 REG103FA-5 REG103FA-5/500 REG103FA-5/500G3 REG103FA-5KTTT REG103FA-5KTTTG3 REG103FA-A REG103FA-A/500 REG103FA-A/500E3 REG103FA-AKTTT REG103FA-AKTTTG3 REG103GA-2.5 REG103GA-2.5G4 REG103GA-3 REG103GA-3.3 REG103GA-3.3/2K5 REG103GA-3.3/2K5G4 REG103GA-3.3G4 REG103GA-5 REG103GA-5/2K5 REG103GA-5/2K5G4 REG103GA-5G4 REG103GA-A REG103GA-A/2K5 REG103GA-A/2K5G4 REG103GA-AG4 REG103UA-2.5 REG103UA-2.5/2K5 REG103UA-2.5G4 REG103UA-3 REG103UA-3.3 REG103UA-3.3/2K5 REG103UA-3.3/2K5G4 REG103UA-3.3G4 REG103UA-5 REG103UA-5/2K5 REG103UA-5G4 REG103UA-A REG103UA-A/2K5 REG103UA-A/2K5G4 REG103UA-AG4
REG103FAAKTTT, REG103FA AKTTT
