Datasheet Texas Instruments LMH6714MF/NOPB — Даташит
| Серия | LMH6714 |
| Модель | LMH6714MF/NOPB |
Одиночный широкополосный видеооперационный усилитель 5-SOT-23 от -40 до 85
Wideband Video Op Amp; Single, Single w/Shutdown & Quad datasheet
PDF, 1.5 Мб, Версия: G, Файл опубликован: 4 апр 2013
| 34 предложений от 18 поставщиков Микросхема Видеоусилитель, TEXAS INSTRUMENTS LMH6714MF/NOPB Video Amplifier, 1 Amplifiers, 400MHz, 1800V/µs, -40℃, 85℃, 70mA | |||
| LMH6714MF/NOPB National Semiconductor | 107 ₽ | ||
| LMH6714MF/NOPB Texas Instruments | 238 ₽ | ||
| LMH6714MF/NOPB Texas Instruments | от 380 ₽ | ||
| LMH6714MF/NOPB Texas Instruments | по запросу | ||
| Pin | 5 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | A95A |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| 2nd Harmonic | 58 dBc |
| 3rd Harmonic | 70 dBc |
| @ MHz | 20 |
| Acl, min spec gain | 1 V/V |
| Additional Features | N/A |
| Архитектура | Bipolar,Current FB |
| BW @ Acl | 400 МГц |
| CMRR(Min) | 48 дБ |
| CMRR(Typ) | 54 дБ |
| GBW(Typ) | 400 МГц |
| Input Bias Current(Max) | 10000000 pA |
| Iq per channel(Max) | 7.5 мА |
| Iq per channel(Typ) | 5.6 мА |
| Количество каналов | 1 |
| Offset Drift(Typ) | 8 uV/C |
| Output Current(Typ) | 70 мА |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rail-to-Rail | No |
| Rating | Catalog |
| Slew Rate(Typ) | 1800 V/us |
| Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 8 +5V=5, +/-5V=10 |
| Vn at 1kHz(Typ) | 3.4 нВ/rtГц |
| Vn at Flatband(Typ) | 3.4 нВ/rtГц |
| Vos (Offset Voltage @ 25C)(Max) | 6 мВ |
- Evaluation Modules & Boards: LMH730216
 Evaluation Board for High-Speed Single Op Amp in the 5- 6-Pin SOT-23 Package
- Evaluation Modules & Boards: LMH730227
 Evaluation Board for High-Speed Single Op Amp in the 8-Pin SOIC Package
- Evaluation Modules & Boards: LMH730316
 LMH730316 Evaluation Board for High-Speed Single Op Amp in the 5-/6-Pin SOT-23 Package
Серия: LMH6714 (6)
- LMH6714MA LMH6714MA/NOPB LMH6714MAX/NOPB LMH6714MF LMH6714MF/NOPB LMH6714MFX/NOPB
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
