Datasheet Texas Instruments OPA2677H — Даташит
СерияOPA2677
МодельOPA2677H
Двойной широкополосный операционный усилитель SpeedPlus™ с высоким выходным током 8-HSOP от -40 до 85
Dual, Wideband, High Output Current Operational Amplifier datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 2 июл 2008
Package TypeDTJ
Industry STD TermHSOIC
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.39
Max Height (мм)1.75
2nd Harmonic(dBc)72
3rd Harmonic(dBc)81
@ MHz5
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)1.65 | 1ku
АрхитектураBipolar
Current FB
BW @ Acl(MHz)220
CMRR(Min)(dB)51
CMRR(Typ)(dB)55
GBW(Typ)(MHz)220
Input Bias Current(Max)(pA)35000000
Iq per channel(Max)(mA)18.6
Iq per channel(Typ)(mA)18
Number of Channels(#)2
Offset Drift(Typ)(uV/C)4
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)500
Package GroupSO PowerPAD
SOIC
VQFN
Package Size: mm2:W x L (PKG)16VQFN: 16 mm2: 4 x 4(VQFN)
8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailNo
Slew Rate(Typ)(V/us)2000
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12.6
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4
Vn at Flatband(Typ)(nV/rtHz)2
Vos (Offset Voltage @ 25C)(Max)(mV)4.5
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Current Feedback Amplifiers: Review, Stability Analysis, and Applications
    PDF, 53 Кб, Файл опубликован: 20 ноя 2000
    The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2677H
