Datasheet Texas Instruments TPS61280AYFFR — Даташит
СерияTPS61280A
МодельTPS61280AYFFR
TPS6128xA ИС низковольтного внешнего управления питанием 16-DSBGA от -40 до 85
TPS6128xA Low-, Wide- Voltage Battery Front-End DC/DC Converter Single-Cell Li-Ion, Ni-Rich, Si-Anode Applications datasheet
PDF, 2.4 Мб, Версия: B, Файл опубликован: 14 ноя 2014
Pin1616
Package TypeYFFYFF
Industry STD TermDSBGADSBGA
JEDEC CodeS-XBGA-NS-XBGA-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка61280ATPS
Thickness (мм).425.425
Pitch (мм).4.4
Max Height (мм).625.625
Duty Cycle(Max)90 %
Iq(Typ)0.015 мА
Package GroupDSBGA
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Dynamic Voltage Scaling,Enable,I2C,Light Load Efficiency,Output Discharge
Switch Current Limit(Typ)5 A
Switching Frequency(Max)2300 kHz
ТипConverter
Vin(Max)4.85 В
Vin(Min)2.3 В
Vout(Max)4.4 В
Vout(Min)2.85 В
  • Evaluation Modules & Boards: TPS61280EVM-585
    Low-, Wide- Voltage Battery Front-End DC/DC Converter with I2C interface Evaluation Module
  • Choosing the Boost With Bypass or Pass Through
    PDF, 311 Кб, Файл опубликован: 27 июн 2017
    For some applications – smart phones, radio-frequency power amplifiers (RF PA), and USB connectors,for example – the load requires a higher voltage to operate than the minimum voltage. The conventionalboost converter outputs greater voltage than the input voltage but cannot handle inputs that swing abovethe desired output. New topologies combining a boost converter plus a bypass switch or bo
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
Серия: TPS61280A (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61280AYFFR
