Datasheet ТI 5HC40103F3AS228 — Даташит
СерияCD54HC40103
Модель5HC40103F3AS228
Datasheet Texas Instruments 5HC40103F3AS228
Высокоскоростная КМОП-логика, 8-ступенчатые синхронные счетчики обратного счета, 16-CDIP, от -55 до 125
CD54HC40103, CD74HC40103, CD74HCT40103 datasheet
PDF, 460 Кб, Версия: D, Файл опубликован: 16 окт 2003
  • Live Insertion
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC40103 (4)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments 5HC40103F3AS228
Политика конфиденциальности
