Datasheet Texas Instruments LM3S1F11-IBZ80-A2 — Даташит
СерияLM3S1F11
МодельLM3S1F11-IBZ80-A2
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S1F11 Microcontroller Data Sheet datasheet
PDF, 5.8 Мб, Версия: C, Файл опубликован: 3 июл 2014
IC MCU 32BIT 384KB FLASH 108BGA. ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 1000 Microcontroller IC 32-Bit 80MHz 384KB (384K x 8) FLASH...
LM3S1F11-IBZ80-A2T
64 ₽
Рутоника
LM3S1F11-IBZ80-A2T
LM3S1F11-IBZ80-A2
TradeElectronics
LM3S1F11-IBZ80-A2T
Pin108108
Package TypeZCRZCR
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаLM3S1F11IBZ80
Width (мм)1010
Length (мм)1010
Thickness (мм).95.95
Pitch (мм).8.8
Max Height (мм)1.51.5
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S1F11IBZ80A2, LM3S1F11 IBZ80 A2
На английском языке: Datasheet Texas Instruments LM3S1F11-IBZ80-A2
