Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI 5962-9678001QXA — Даташит
СерияSN54LVTH162245
Модель5962-9678001QXA
Datasheet Texas Instruments 5962-9678001QXA
16-битные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями 48-CFP от -55 до 125
3.3-V ABT 16-BIT BUS TRANSCEIVERS WITH 3-STATE OUTPUTS--SN74LVTH162245 datasheet
PDF, 948 Кб, Версия: Q, Файл опубликован: 1 ноя 2006
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH162245 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
59629678001QXA, 5962 9678001QXA
На английском языке: Datasheet Texas Instruments 5962-9678001QXA
Политика конфиденциальности
