Datasheet Texas Instruments LMP7731MF/NOPB — Даташит
СерияLMP7731
МодельLMP7731MF/NOPB
Прецизионный малошумящий усилитель RRIO 2,9 нВ/кв.(Гц) 5-SOT-23 от -40 до 125
LMP7731 2.9 nV/sqrt(Hz) Low Noise, Precision, RRIO Amplifier datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 27 мар 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY1000
МаркировкаAY3A
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)101 дБ
CMRR(Typ)120 дБ
GBW(Typ)22 МГц
Input Bias Current(Max)50000 pA
Iq per channel(Max)3 мА
Iq per channel(Typ)2.2 мА
Количество каналов1
Offset Drift(Typ)0.5 uV/C
Output Current(Typ)47 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)2.4 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2.9 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Evaluation Modules & Boards: AFE2256EVM
    AFE2256 Evaluation Module for 256-Channel Analog Front End for Digital X-Ray Flat Panel Detectors
  • AN-1873 DC Parameters (Rev. A)
    PDF, 91 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application report discusses the DC parameters.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMP7731MF/NOPB
