Datasheet Texas Instruments TPS53355DQPR — Даташит
СерияTPS53355
МодельTPS53355DQPR
Входное напряжение от 1,5 до 15 В (смещение от 4,5 до 25 В), синхронизирующий понижающий преобразователь SWIFT™ на 30 А с Eco-mode™ 22-LSON-CLIP от -40 до 85
TPS53355 High-Efficiency 30-A Synchronous Buck SWIFTв„ў Converter With Eco-mode datasheet
PDF, 1.9 Мб, Версия: D, Файл опубликован: 30 ноя 2016
Pin22
Package TypeDQP
Industry STD TermLSON-CLIP
JEDEC CodeR-PSSO-N
Package QTY2500
Маркировка53355DQP
Width (мм)5
Length (мм)6
Thickness (мм)1.5
Pitch (мм).5
Max Height (мм)1.5
Control ModeD-CAP
Duty Cycle(Max)90 %
Iout(Max)30 A
Iq(Typ)0.32 мА
Package GroupLSON-CLIP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Synchronous Rectification
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)250 kHz
ТипConverter
Vin(Max)15 В
Vin(Min)1.5 В
Vout(Max)5.5 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS53355EVM-743
    High-Efficiency, 30-A,Synchronous Buck Converter With Eco-mode Control Scheme Evaluation Module
  • Minimizing Switching Ringing at TPS53355 and TPS53353 Family Devices
    PDF, 10.0 Мб, Файл опубликован: 10 июл 2017
    This document describes switching ringing reduction methods and lab bench test results. This application report is applicable to TPS53355. In addition, this device belongs to the same family as the TPS53353 devices.
  • Not All Jitter Is Created Equal (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 июл 2015
    This application report offers a tutorial discussion on jitter in switching DC-DC converters. Not all power supply designs are equally susceptible to jitter, nor are they equally affected by jitter. Modes of switching jitter are defined and explained for several popular control architectures, which are then analyzed for sources of jitter. An example contrasting the amount of jitter and effect on o
  • SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator IC
    PDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS53355 (3)
На английском языке: Datasheet Texas Instruments TPS53355DQPR
