Datasheet Texas Instruments LM57FPW — Даташит
СерияLM57
МодельLM57FPW
В±0.7В°C Temperature Sensor with Resistor-Programmable Temperature Switch 8-TSSOP -50 to 150
LM57 Resistor-Programmable Temperature Switch and Analog Temperature Sensor datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 15 июл 2015
28 предложений от 13 поставщиков
THERMOSTAT PROG ACT HI/LO 8TSSOP. Thermostat Programmable Active High, Active Low Open Drain, Push-Pull 8-TSSOP. Temperature Sensors - Thermostats - Solid...
LM57FPW
30 ₽
Рутоника
LM57FPW
78 ₽
LM57FPW
89 ₽
Элитан
LM57FPW
309 ₽
Package TypePW
Industry STD TermTSSOP
Package QTY150
МаркировкаLM57F
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
# Comparators1
Accuracy Over Temp Range(Max)1.5 C
InterfaceAnalog Output,Switch
Рабочий диапазон температурот -50 до 150 C
Тип выходаOpen Drain,Push Pull
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
Sensor Gain-5.2 to -12.9 mV/Deg C
SetPoint TypeResistor Programmable
SetPoint Value-40 to 150 deg C
Special FeaturesBuilt-in Hysteresis,Hysteresis (5В°C or 10В°C),Temperature Sensor and Switch,Trip Test
Supply Current(Typ)24 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.4 В
  • Evaluation Modules & Boards: LM57EVM
    Evalution Module for Analog Temperature Sensor
  • AN-1984 LM57 Temperature Switch vs Thermistors (Rev. C)
    PDF, 83 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report compares the system design and performance advantages of sensing with TexasInstruments LM57 CMOS integrated circuit sensor as compared to a thermal-resistant (thermistor) sensorcircuit.
  • Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
На английском языке: Datasheet Texas Instruments LM57FPW
