Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TAS5001IPFBG4 — Даташит
СерияTAS5001
МодельTAS5001IPFBG4
Цифровой аудиопроцессор ШИМ 48-TQFP от -40 до 85
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
RoHSНе совместим
  • TAS5001-5122C2EVM Application Report (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 14 апр 2008
  • System Design Considerations for True Digital Audio Power Amplifiers (Rev. A)
    PDF, 675 Кб, Версия: A, Файл опубликован: 12 ноя 2001
    This report describes the conversion of pulse-code-modulated (PCM) to pulse-width-modulated (PWM) signals using Texas Instruments TDAA modulation devices (TAS50xx) and signal amplification using Texas Instruments family of H-bridge output stages (TAS51xx). It includes a detailed discussion of power supply voltage requirements, output circuit filters, and thermal dissipation. An example stereo appl
  • Power Supply Recommendations for DVD Receivers
    PDF, 153 Кб, Файл опубликован: 4 май 2005
    Selecting the optimal power supply for a non feed back digital amplifier can bechallenging. Music is dynamic, so the power consumption is changing dramatically,from almost zero to maximum within a few ms.Designing the power supply so powerful that it can deliver the total amplifier outputpower continuously is too costly and usually unnecessary.Designing the power supply too small gives p
  • PSRR for Purepath Digital Audio Amplifiers
    PDF, 159 Кб, Файл опубликован: 15 апр 2005
Серия: TAS5001 (5)
  • Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5001IPFBG4
