Datasheet Texas Instruments UC2854BJ — Даташит
СерияUC2854BM
МодельUC2854BJ
Усовершенствованный пререгулятор высокого коэффициента мощности 16-CDIP от -40 до 85
UCx854 High-Power Factor Preregulator datasheet
PDF, 949 Кб, Версия: A, Файл опубликован: 16 дек 2016
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC2854BJ
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCCM
Duty Cycle(Max)95 %
Package GroupCDIP
RatingMilitary
Special Features> 750W Applications,Average Current Mode,Enable
UVLO Thresholds On/Off16/10 В
RoHSSee ti.com
  • U-134 UC3854 Controlled Power Factor Correction Circuit Design
    PDF, 346 Кб, Файл опубликован: 5 сен 1999
    The UC1854 provides active power factor correction for power systems that otherwise would draw non-sinusoidal current from sinusoidal power lines. This device implements all the control functions necessary to build a power supply capable of optimally using available power-line current while minimizing line-current distortion. This application note describes the concepts and design of a boost prere
  • DN-39E Optimizing Performance in UC3854 Power Factor Correction Applications
    PDF, 277 Кб, Файл опубликован: 5 сен 1999
    The performance of the UC3854 Power-Factor Correction IC in the 250W application example has been evaluated using a precision PFC/THD instrument. The result was a power factor of 0.999 and Total Harmonic Distortion (THD) of 3.81%, measured to the 50th line frequency harmonic at nominal line and full load. Users should get similar results at these conditions. as well as over most line and load rang
  • DN-41 Extend Current Transformer Range
    PDF, 37 Кб, Файл опубликован: 5 сен 1999
    The problems with self reset of current transformers for unipolar pulse applications can be overcome with simple forced-reset techniques derived from magnetic amplifiers. Duty factors above 90% are achievable with these techniques. This design note describes a circuit configured for forced reset and a configuration that generates a negative voltage from the current transformer.
  • Accurate PWM Duty Cycle Clamp
    PDF, 58 Кб, Файл опубликован: 25 янв 2002
    Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UC2854BM (1)
  • UC2854BJ
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC2854BJ
