Datasheet Texas Instruments ADS7852Y/2KG4 — Даташит
СерияADS7852
МодельADS7852Y/2KG4
12-битный 8-канальный аналого-цифровой преобразователь с параллельным выходом 32-TQFP
ADS7852: 12-Bit, 8-Channel, Parallel Output Analog-to-Digital Converter datasheet
PDF, 370 Кб, Версия: C, Файл опубликован: 22 июл 2004
Pin32
Package TypePBS
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Width (мм)5
Length (мм)5
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# Input Channels8
Analog Voltage AVDD(Max)(V)5.25
Analog Voltage AVDD(Min)(V)4.75
Approx. Price (US$)3.57 | 1ku
АрхитектураSAR
Digital Supply(Max)(V)5.25
Digital Supply(Min)(V)4.75
INL(Max)(+/-LSB)1
Input Range(Max)(V)5
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceParallel
Operating Temperature Range(C)-40 to 85
Package GroupTQFP
Package Size: mm2:W x L (PKG)32TQFP: 49 mm2: 7 x 7(TQFP)
Power Consumption(Typ)(mW)13
Reference ModeExt
Int
Resolution(Bits)12
SINAD(dB)N/A
SNR(dB)72
Sample Rate (max)(SPS)500kSPS
THD(Typ)(dB)-77
RoHSНе совместим
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7852Y/2KG4
