Datasheet Texas Instruments SN65HVD10QDRG4 — Даташит
| Серия | SN65HVD10 |
| Модель | SN65HVD10QDRG4 |
Полудуплексный трансивер RS-485, 3,3 В, 8-SOIC, 32 Мбит/с, от -40 до 125
SNx5HVD1x 3.3-V RS-485 Transceivers datasheet
PDF, 1.2 Мб, Версия: O, Файл опубликован: 1 фев 2017
Купить SN65HVD10QDRG4 на РадиоЛоцман.Цены — от 84 до 833 ₽13 предложений от 13 поставщиков IC TRANSCEIVER HALF 1/1 8SOIC. 1/1 Transceiver Half RS422, RS485 8-SOIC. Interface - Drivers, Receivers, Transceivers | |||
| SN65HVD10QDRG4 Texas Instruments | 84 ₽ | ||
| SN65HVD10QDRG4 Texas Instruments | по запросу | ||
| SN65HVD10QDRG4 | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | VP10Q |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Common Mode Range | -7 to 12 |
| Duplex | Half |
| Fail Safe | Idle,Open,Short |
| Fault Protection | -9 to 14 В |
| HBM ESD | 16 kV |
| ICC(Max) | 15.5 мА |
| IEC 61000-4-2 Contact | N/A +/- kV |
| Isolated | No |
| No. of RX | 1 |
| No. of TX | 1 |
| Number of Nodes | 64 |
| Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
| Package Group | SOIC |
| Rating | Catalog |
| Signaling Rate(Max) | 32 Mbps |
| Supply Voltage(s)(Nom) | 3.3 В |
- Evaluation Modules & Boards: RS485-HF-DPLX-EVM
RS-485 Half-Duplex Evaluation Module
- Operating RS-485 Transceivers at Fast Signaling RatesPDF, 631 Кб, Файл опубликован: 15 ноя 2004
The TIA/EIA-485-A standard specifies characteristics for RS-485 signaling. Most applications operate below 10 Mbps but it is often possible to signal at higher rates. This application report examines the constraints on high-speed signaling and presents results using the SN65HVD10 transceiver as one example transceiver. Our method is to measure the eye patterns at the end of a 10-m cable under vary - The RS-485 Unit Load and Maximum Number of Bus ConnectionsPDF, 197 Кб, Файл опубликован: 15 мар 2004
The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
Серия: SN65HVD10 (9)
- Semiconductors > Interface > RS-485/RS-422
