Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS7800BH-BI — Даташит
СерияADS7800
МодельADS7800BH-BI
12-битный аналого-цифровой преобразователь с дискретизацией 3 мкс 24-CDIP SB
ADS7800: 12-Bit 3-µs Sampling Analog-to-Digital Converter datasheet
PDF, 845 Кб, Версия: A, Файл опубликован: 17 фев 2004
Pin24
Package TypeJD
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Width (мм)7.37
Length (мм)27.94
Thickness (мм)3.5
Pitch (мм)2.54
Max Height (мм)4.45
Рекомендуемая замена
ReplacementADS7800BH
Replacement CodeS
# Input Channels1
Analog Voltage AVDD(Max)(V)5.25
Analog Voltage AVDD(Min)(V)4.75
Approx. Price (US$)31.55 | 1ku
АрхитектураSAR
Digital Supply(Max)(V)5.25
Digital Supply(Min)(V)4.75
INL(Max)(+/-LSB)0.5
Input Range(Max)(V)10
Input Range(Min)(V)-10
Тип входаSingle-Ended
Integrated FeaturesOscillator
InterfaceParallel
Multi-Channel ConfigurationN/A
Operating Temperature Range(C)-40 to 85
Package Size: mm2:W x L (PKG)See datasheet (CDIP SB)
See datasheet (PDIP)
Power Consumption(Typ)(mW)135
Reference ModeInt
Resolution(Bits)12
SINAD(dB)72
SNR(dB)73
Sample Rate (max)(SPS)333kSPS
THD(Typ)(dB)-80
RoHSНе совместим
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Interleaving Analog-to-Digital Converters
    PDF, 64 Кб, Файл опубликован: 2 окт 2000
    It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error.
  • Using the ADS7800 12 Bit ADC with Unipolar Input Signals
    PDF, 37 Кб, Файл опубликован: 2 окт 2000
    The ADS7800 12 bit Sampling analog-to-digital-converter is designed to operate with bipolar inputs of В±5V or В±10V. With the addition of an external amplifier, the ADS7800 can be used for 10V or 20V unipolar inputs. Four unipolar input options are shown in this Bulletin.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • What Designers Should Know About Data Converter Drift
    PDF, 95 Кб, Файл опубликован: 2 окт 2000
    Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
  • A Clarification of Use of High-Speed S/H to Improve Sampling ADC Performance
    PDF, 53 Кб, Файл опубликован: 2 окт 2000
    You know it's going to be one of those days when you see the printed version of an article you wrote and realize that you have made an error in the presentation of your ideas. This is what happened to me as I read Use High Speed S/H to Improve Sampling ADC Performance (Design Update, Vol.1, No.1). This article will rectify the situation and further illuminate some important performance aspe
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
ADS7800BHBI, ADS7800BH BI
На английском языке: Datasheet Texas Instruments ADS7800BH-BI
