Datasheet Texas Instruments REG102GA-5/2K5 — Даташит
СерияREG102
МодельREG102GA-5/2K5
Линейный стабилизатор напряжения с низким уровнем шума, малым падением напряжения, 250 мА 6-SOT-223 от -40 до 85
DMOS 250mA Low-Dropout Regulator datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 8 сен 2005
Pin6
Package TypeDCQ
Industry STD TermSOT
МаркировкаR102G50
Width (мм)3.5
Length (мм)6.5
Thickness (мм)1.6
Max Height (мм)1.8
Accuracy(%)2.5
Additional FeaturesEnable
Fast Transient Response
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)1.05 | 1ku
Fixed Output Options(V)2.5
2.8
2.85
3
3.3
5
Iout(Max)(A)0.25
Iq(Typ)(mA)0.4
Noise(uVrms)28
Operating Temperature Range(C)-40 to 85
Output Capacitor TypeCap Free
Ceramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)46
Package GroupSOT-223
Package Size: mm2:W x L (PKG)6SOT-223: 46 mm2: 7.06 x 6.5(SOT-223)
Regulated Outputs(#)1
Vdo(Typ)(mV)150
Vin(Max)(V)10
Vin(Min)(V)2.2
Vout(Max)(V)5.5
Vout(Min)(V)2.5
RoHSНе совместим
  • Evaluation Modules & Boards: TPS79328EVM
    TPS79328 Evaluation Module
  • Evaluation Modules & Boards: TPS76XXXEVM-125
    TPS76xxxEVM-125 Universal SOT-23 LDO Evaluation Module
  • Evaluation Modules & Boards: TPS76933EVM-127
    SOT23 LDO, 5 V to 1.0 V, 100mA output power supply
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Evaluation Modules & Boards: TPS76901EVM-127
    SOT23 LDO, 5 V to 1.8 V, 100mA output power supply
  • Evaluation Modules & Boards: TPS79301EVM
    TPS79301 Evaluation Module
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
REG102GA5/2K5, REG102GA 5/2K5
На английском языке: Datasheet Texas Instruments REG102GA-5/2K5
