Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS5401DGQT — Даташит
СерияTPS5401
МодельTPS5401DGQT
Входное напряжение от 3,5 В до 42 В, понижающий преобразователь 0,5 А 10-MSOP-PowerPAD от -40 до 150
TPS5401 0.5-A, 42-V Input, Step-Down Converter datasheet
PDF, 1.9 Мб, Версия: B, Файл опубликован: 10 фев 2016
Pin10
Package TypeDGQ
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY250
CarrierSMALL T&R
Маркировка5401
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)0.5 A
Iq(Typ)0.116 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupMSOP-PowerPAD
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Tracking,UVLO Adjustable
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)100 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)3.5 В
Vout(Max)39 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS5401EVM-708
    Evaluation Module for TPS5401 0.5A Step-Down SWIFTВ™ Converter
  • Improved Load Current Capability for Cap-Drop Off-Line Power Supply for E-Meter
    PDF, 502 Кб, Файл опубликован: 27 окт 2011
    Standard electronic electricity meters (e-meters) have traditionally used a capacitive-drop power supply (capdrop) plus linear regulator topology to provide a cost-effective power supply. Today, opposing forces such as an increase in load currents due to more complex AMR and AMI ommunications circuitry and tighter power consumption regulations, force e-meter designers to limit consumption to belo
  • Design Considerations for DC-DC Converters in Fast-Input Slew Rate Applications
    PDF, 191 Кб, Файл опубликован: 5 мар 2015
    This application report describes the ways to optimize the design of DC-DC converters (TPS54040-Q1, TPS54060-Q1, TPS54140-Q1, TPS54160-Q1, TPS54240-Q1, TPS54260-Q1, TPS57040-Q1, TPS57060-Q1, TPS57140-Q1, and TPS57160-Q1) in applications with fast transition at the input voltage on the rising and falling edges. First, the issues faced under such a scenario are analyzed. Then, design considerations
  • Designing Low Cost Flyback Power Supply Using Boost Converter (TPS61165) for HF
    PDF, 4.2 Мб, Файл опубликован: 17 апр 2014
    TPS61165, LMR14206, TPS5401, AMC1100, TLV1117I-33, TLV1117I-50 Designing low cost flyback supply using boost converter for HF Inverter
Серия: TPS5401 (3)
На английском языке: Datasheet Texas Instruments TPS5401DGQT
