Datasheet ТI OPA132UAG4 — Даташит
| Серия | OPA132 |
| Модель | OPA132UAG4 |
Высокоскоростные операционные усилители с входом полевого транзистора 8-SOIC от -40 до 125
OPAx132 High-Speed FET-Input Operational Amplifiers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 29 сен 2015
- Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA132 (16)
