Datasheet Texas Instruments 5962-9959901QPA — Даташит
Серия | THS4051M |
Модель | 5962-9959901QPA |
Высокоскоростной усилитель 70 МГц 8-CDIP от -55 до 125
Datasheet
Pin | 8 | 8 |
Package Type | JG | JG |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 9959901QPA | THS4051M |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 9.6 | 9.6 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Additional Features | N/A |
Архитектура | Voltage FB Bipolar |
CMRR(Min)(dB) | 70 |
CMRR(Typ)(dB) | 100 |
GBW(Typ)(MHz) | 70 |
IIB(Max)(pA) | 6000000 |
Iq per channel(Max)(mA) | 10.5 |
Iq per channel(Typ)(mA) | 8.5 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 15 |
Operating Temperature Range(C) | -55 to 125 |
Output Current(Typ)(mA) | 100 |
Package Group | CDIP |
Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
Rail-to-Rail | No |
Rating | Military |
Slew Rate(Typ)(V/us) | 240 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 32 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 9 |
Vn at 1kHz(Typ)(nV/rtHz) | 14 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 10 |
RoHS | TBD |
- Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS4051M (5)
- 5962-9959901Q2A 5962-9959901QPA THS4051MFKB THS4051MJG THS4051MJGB
- Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
59629959901QPA, 5962 9959901QPA
