Datasheet Texas Instruments OPA2695IRGTR — Даташит
СерияOPA2695
МодельOPA2695IRGTR
Сверхширокополосный операционный усилитель с токовой обратной связью и отключением 16-VQFN от -40 до 85
Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 29 авг 2008
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка2695
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
2nd Harmonic73 dBc
3rd Harmonic82 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Current FB
BW @ Acl1100 МГц
CMRR(Min)51 дБ
CMRR(Typ)56 дБ
GBW(Typ)1100 МГц
Input Bias Current(Max)30000000 pA
Iq per channel(Max)13.3 мА
Iq per channel(Typ)12.9 мА
Количество каналов2
Offset Drift(Typ)15 uV/C
Output Current(Typ)120 мА
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 9 mm2: 3 x 3(VQFN) PKG
Rail-to-RailNo
Slew Rate(Typ)2900 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)3.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3.5 мВ
  • Evaluation Modules & Boards: DEM-OPA-SO-2E
    DEM-OPA-SO-2E
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2695IRGTR
