Datasheet Texas Instruments TLV2252QDR — Даташит
Серия | TLV2252 |
Модель | TLV2252QDR |
Двойной низковольтный операционный усилитель малой мощности Rail-To-Rail 8-SOIC от -40 до 125
Advanced LinCMOS Rail-to-Rail Very Low-Power Op Amps Very Low-Power Operational datasheet
PDF, 2.1 Мб, Версия: D, Файл опубликован: 12 авг 2006
![]() 11 предложений от 10 поставщиков Микросхема Буферный усилитель, Dual Rail-To-Rail Low-Voltage Low Power Operational Amplifier 8-SOIC -40℃ to 125℃ | |||
TLV2252QDR Texas Instruments | 492 ₽ | ||
TLV2252QDR Texas Instruments | по запросу | ||
TLV2252QDR | по запросу | ||
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | High Cload Drive |
Approx. Price (US$) | 0.73 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 70 |
CMRR(Typ)(dB) | 83 |
GBW(Typ)(MHz) | 0.2 |
Input Bias Current(Max)(pA) | 60 |
Iq per channel(Max)(mA) | 0.0625 |
Iq per channel(Typ)(mA) | 0.035 |
Number of Channels(#) | 2 |
Offset Drift(Typ)(uV/C) | 0.5 |
Operating Temperature Range(C) | -40 to 125 0 to 70 |
Output Current(Typ)(mA) | 8 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In to V- Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 0.12 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 8 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.7 |
Vn at 1kHz(Typ)(nV/rtHz) | 19 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 1.5 |
RoHS | Не совместим |
- Solid State Voice Recorder Using Flash MSP430PDF, 101 Кб, Файл опубликован: 25 янв 2001
The promise of cost-effective re-programmable MSP430 MCU systems has recently come to fruition with the integration of In-System Programmable (ISP) flash memory. Firmware delivered just in time during manufacturing, updateable code in field-deployed systems, and the elimination of discrete EEPROMs are now design realities. This application report demonstrates the flexibility of in-system programma - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2252 (8)
