Datasheet ТI OPA355UAG4 — Даташит
| Серия | OPA355 |
| Модель | OPA355UAG4 |
2,5 В, 200 МГц GBW, одиночный КМОП-операционный усилитель с отключением, 8-SOIC от -40 до 125
OPA355, 2355, 3355: 200MHz, CMOS Operational Amplifier with Shutdown datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 6 ноя 2003
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA355 (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
