Datasheet Texas Instruments AM26LV32IDG4 — Даташит
| Серия | AM26LV32 |
| Модель | AM26LV32IDG4 |
Низковольтный высокоскоростной четырехкратный дифференциальный линейный приемник 16-SOIC от -40 до 85
AM26LV32 Low-Voltage, High-Speed Quadruple Differential Line Receiver datasheet
PDF, 1.0 Мб, Версия: F, Файл опубликован: 18 ноя 2016
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | AM26LV32I |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| ICC(Max) | 17 мА |
| Рабочий диапазон температур | от -40 до 85,0 до 70 C |
| Package Group | SOIC |
| Rating | Catalog |
| Signaling Rate | 32 Mbps |
| Supply Voltage(s) | 3.3 В |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
Серия: AM26LV32 (17)
- Semiconductors > Interface > RS-485/RS-422
