Datasheet Texas Instruments SN74LVCH32245AZKER — Даташит
СерияSN74LVCH32245A
МодельSN74LVCH32245AZKER
32-битный шинный трансивер с выходом с 3 состояниями 96-LFBGA от -40 до 85
SN74LVCH32245A datasheet
PDF, 789 Кб, Версия: H, Файл опубликован: 12 авг 2003
IC TXRX NON-INVERT 3.6V 96PBGA. Transceiver, Non-Inverting 4 Element 8 Bit per Element 3-State Output 96-PBGA MICROSTAR (13.6x5.6). Logic - Buffers,...
SN74LVCH32245AZKER
81 ₽
SN74LVCH32245AZKER
222 ₽
SN74LVCH32245AZKER
346 ₽
SN74LVCH32245AZKER
Pin96
Package TypeZKE
Industry STD TermBGA MICROSTAR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаCH245A
Width (мм)5.5
Length (мм)13.5
Thickness (мм).85
Pitch (мм).8
Max Height (мм)1.4
Bits32
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupLFBGA
Package Size: mm2:W x L96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)7.1,4.5,4.7,4 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH32245A (2)
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH32245AZKER
