Datasheet Texas Instruments TPS53915RVET — Даташит
СерияTPS53915
МодельTPS53915RVET
Входное напряжение от 1,5 до 18 В (смещение от 4,5 до 25 В), синхронный понижающий преобразователь SWIFT™ на 12 А с PMBus™ 28-VQFN-CLIP от -40 до 85
TPS53915 1.5 to 18-V (4.5 to 25-V Bias) Input, 12-A Synchronous Step-Down SWIFTв„ў Converter With PMBusв„ў datasheet
PDF, 36.4 Мб, Версия: B, Файл опубликован: 8 дек 2014
Pin28
Package TypeRVE
Industry STD TermVQFN-CLIP
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаTPS53915
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).4
Max Height (мм)1
Control ModeD-CAP3
Duty Cycle(Max)80 %
Iout(Max)12 A
Iq(Typ)1.35 мА
Package GroupVQFN-CLIP
Regulated Outputs1
Special FeaturesDynamic Voltage Scaling,Enable,Light Load Efficiency,PMBus,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Voltage Margining
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)250 kHz
ТипConverter
Vin(Max)18 В
Vin(Min)1.5 В
Vout(Max)5.5 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS53915EVM-587
    TPS53915EVM-587 Single Synchronous Step-Down Converter Evaluation Module
  • Accuracy-Enhanced Ramp-Generation Design for D-CAP3 Modulation (Rev. A)
    PDF, 493 Кб, Версия: A, Файл опубликован: 25 апр 2016
    D-CAP and D-CAP2 control schemes have been widely used in TI Switched-Mode DC-DC converters due to their fast transient response and no off-chip compensation. Offset generated by current sense ramp adds an error to VFB and Vout and hence reduces DC accuracy. This paper introduces a new D-CAP3 control scheme which greatly improves DC accuracy of the converter while maintaining the same fast transie
  • Not All Jitter Is Created Equal (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 июл 2015
    This application report offers a tutorial discussion on jitter in switching DC-DC converters. Not all power supply designs are equally susceptible to jitter, nor are they equally affected by jitter. Modes of switching jitter are defined and explained for several popular control architectures, which are then analyzed for sources of jitter. An example contrasting the amount of jitter and effect on o
  • SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator IC
    PDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS53915 (2)
На английском языке: Datasheet Texas Instruments TPS53915RVET
