Datasheet Texas Instruments 74ACT11004DBLE — Даташит
Серия74ACT11004
Модель74ACT11004DBLE
Шестигранные инверторы 20-SSOP от -40 до 85
Hex Inverter datasheet
PDF, 560 Кб, Версия: B, Файл опубликован: 1 июн 1997
SN74ACT11004DBLE
LifeElectronics
74ACT11004DBLE
Pin20
Package TypeDB
Industry STD TermSSOP
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.94 | 1ku
Bits(#)6
F @ Nom Voltage(Max)(Mhz)90
ICC @ Nom Voltage(Max)(mA)0.04
Тип входаTTL
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаCMOS
Package GroupSSOP
Schmitt TriggerNo
Technology FamilyACT
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)9.7
RoHSНе совместим
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments 74ACT11004DBLE
