Datasheet Texas Instruments LMH6643MAX/NOPB — Даташит
СерияLMH6643
МодельLMH6643MAX/NOPB
Усилители с выходом Rail-to-Rail малой мощности, 130 МГц, 75 мА, 8-SOIC от -40 до 85
LMH664x Low Power, 130 MHz, 75 mA Rail-to-Rail Output Amplifiers datasheet
PDF, 1.8 Мб, Версия: Q, Файл опубликован: 20 сен 2014
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка43MALMH66
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic80 dBc
3rd Harmonic65 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl130 МГц
CMRR(Min)74 дБ
CMRR(Typ)95 дБ
GBW(Typ)130 МГц
Input Bias Current(Max)2600000 pA
Iq per channel(Max)5 мА
Iq per channel(Typ)2.7 мА
Количество каналов2
Offset Drift(Typ)5 uV/C
Output Current(Typ)115 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)135 V/us
Total Supply Voltage(Max)12.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)17 нВ/rtГц
Vn at Flatband(Typ)17 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: LMH730123
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
  • Evaluation Modules & Boards: LMH730036
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin SOIC Package
  • AN-1240 Video Transmission Over Twisted Pair Wire (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 1 май 2013
    The circuits in Figure 1 and Figure 2 transmit NTSC video signals over twisted pair wire. They weredesigned and tested for transmitting video on inexpensive CAT-3 twisted pair wire. Even when transmittingon 1000 feet of wire, good quality color video was displayed on a monitor with an NTSC input. Both thetransmit and receive circuits use the LMH6643 dual op-amp that has the proper bandwidth
  • Lower System Cost Solution for Transmitting Video
    PDF, 80 Кб, Файл опубликован: 6 мар 2003
  • AN-1244 Photo-Diode Current-to-Voltage Converters (Rev. B)
    PDF, 132 Кб, Версия: B, Файл опубликован: 1 май 2013
    Converting the small output current of a photo-diode transducer to a fast responding voltage is oftenchallenging. This application report provides some ways to use high-speed current feedback and voltagefeedback op amps to do the job.
На английском языке: Datasheet Texas Instruments LMH6643MAX/NOPB
